Disables a pending one-shot or periodic ELRP request for the specified VLAN or for all dynamic VLANs.
vlan_name | Specifies a VLAN name. |
dynamic-vlans | Removes all ELRP configuration options for dynamically created VLANs. |
N/A.
This command disables a pending one-shot or periodic ELRP request for the specified VLAN or dynamic VLANs.
To configure periodic transmission of ELRP packets, use the configure elrp-client periodic command.
The ELRP client must be enabled globally in order for it to work on any VLANs. Use the enable elrp-client command to globally enable the ELRP client.
The ELRP client can be disabled globally so that none of the ELRP VLAN configurations take effect. Use the disable elrp-client command to globally disable the ELRP client.
The following command disables a pending ELRP request on VLAN elrp1:
unconfigure elrp-client elrp1
This command was first available in ExtremeXOS 11.1.
The dynamic-vlans option was added in ExtremeXOS 22.3.
